NI TestStand
Custom Step Type on TS 2017 compatible with TS 2016, error -17339
I created a custom step type in TS 2017, and I checked the option in Version > Set Earliest TestStand Version that can Use this Type to 16.0.0.0.
Then when I tried to load the step type in TS 2016 I got this error:
Sequence Editor
Unable to read object: object name not found.
The types file 'C:\Users\Public\Documents\National Instruments\TestStand 2016 (32-bit)\Components\TypePalettes\Test.ini' could not be loaded.
Error Code: -17339
I created a very simple Step Type and I got the same error.
Some ideas?
Freddy
(2,255 Views)
Hey Freddy,
Try the steps out in this KB - http://digital.ni.com/public.nsf/allkb/0C0504151A6C48828625729F006ED2A4?OpenDocument
You'll want to save your types in a new sequence file rather than a specific .ini file, and then save the sequence file for a previous version.
Roxy
(2,238 Views)
I copied the type definitions to a new .ini file in TS 2016. But, in fact my error was related to the DLL called inside the TSDotNetSupport.dll, which is specific for each version of TestStand (I think so).
I didn't test the compatibility option in the properties.
Freddy
(2,195 Views)
