NI TestStand
Custom TS UI won't register events
I have created a custom TestStand UI in LabVIEW 2024 Q3, using TestStand 2024 Q4.
The UI works on the development PC, but the production PC doesn't show up anything I post from the sequences using PostUIMessage.
I created some popup windows in the test sequences to be sure, the TestStand Engine is running. The message popups show up, so the test program is working.
I use DebugView to output some strings from the LabVIEW code, and there I see something coming not from my code.
In the line 27 of the logfile I see an error caused by
NationalInstruments.LabVIEW.CrossDomainServer.DNSetAssemblyResolvePaths(LVAssembly** lvAssemblyArray, UInt32 size)
Does anyone has an idea what goes wrong? The execution works well in the sequence editor.
(234 Views)
Does your sequence run on the production PC using one of the Example OIs?
Is PostUIMessage called from TestStand directly or from a code module?
(222 Views)
I have just tested it with the example full featured UI, it doesn't work too:
I already deinstalled ALL NI products and re-installed them --> no change
I changed the hard disc of the PC to a brand new one and installed everything --> no change.
PostUIMessage is called directly from TestStand seuqence files, among others the process model
(203 Views)
