NI TestStand
Custom code to be executed when step is moved in sequence
Hello All,
I'm using a customized SequenceEditor GUI in my project.
I would like create a custom code module, which would run when the step is moved in the sequence, so the position of the step is changed.
Can I trigger somehow to that?
How could I get the value change of the Step.StepIndex?
Or is there any UImessage which could be used?
Thank you in advance.
CsBihacker
Message 1 of 1
(1,817 Views)
