NI TestStand
Custom return from step to other step to point where it called
I have sequence A: Sequence A calls Sequence B, Sequence B call sequence C.
I want to interrupt C at some point BUT return to A (not B that called C) and continue execution at A.
I tried to understand how to do it with Runstate.caller but did not success int it...maximum that i success
to return to A (by calling that sequence from C) but it started from the start - I need it from the point that A called B ...e.g. continue the A execution
Thank you!
Message 1 of 8
(3,670 Views)
Better explanation perhaps:
i need to jump for main sequence BUT to the point where it called the other sequence and continue the execution form the NEXT step,e.g. in other words it like have pointer at "parent" sequence and if something happens i want to break the execution of "child sequence" and return exactly to the next step of execution of "parent" sequence to continue the execution.
I tried to call "sequence call but it unfortunately start the "parent" sequence from the beginning...
Thank you, Yuri
Message 2 of 8
(3,647 Views)
attached the picture
Message 3 of 8
(3,644 Views)
Attached sequence that i talked about + explanation
Message 4 of 8
(3,638 Views)
Hello yemelian:
Let me see all the information that you upload.
Message 5 of 8
(3,620 Views)
Message 6 of 8
(3,601 Views)
I saw it, but it is other thing. I wrote about jumping fro custom place between sequences and at that place talking about threads... different topic.
Anyway thank you
Message 7 of 8
(3,597 Views)
I found a workaround:
Runstate.Caller.Cleanup=TRUE
Message 8 of 8
(3,558 Views)
