NI TestStand
Custom run time error message into C# UI
I'm trying to get the error message for the last step into my C# UI (using TestStand3.5).
I've tryed the GetRunTimeErrorMessage in the UIMsg_Trace message event, but it doesn't work.
Probably I should use the PostStepRunTimeError callback instead? Is there a sample code available in C# using it?
(3,286 Views)
I'm getting the error code and the message, se below, but I also want to get the location info as in the standard TS error popup.
The boolean Occurred parameter seems to be false even if I get an error. Is it reset to false or something?
int
frameID = 0;
errorCode = axExecutionViewMgrs[index].Thread.GetSequenceContext(0,
out frameID).AsPropertyObject().GetValNumber("Parameters.ErrorLoad.Code", 0);
details = axExecutionViewMgrs[index].Thread.GetSequenceContext(0,
out frameID).AsPropertyObject().GetValString("Parameters.ErrorLoad.Msg", 0);
location = axExecutionViewMgrs[index].Thread.GetSequenceContext(0,
out frameID).AsPropertyObject().GetValBoolean("Parameters.ErrorLoad.Occurred", 0);
(3,277 Views)
