NI TestStand
Custom step type revision
I have created several custom step types, but the names are not displayed correctly when I insert a step in a sequence. This worked fine in TS 2.0, but not in 3.0. Is there something that needs to be done with the version of the step type to be correctly recognized in TS 3.0.
Scott Trosper
(2,849 Views)
Scott -
I am not aware of any issues like this. The version of the step type should not make a difference. Basically the Default Step Name Expression on the General tab of the Step Type Properties dialog box defines the name of the step at insert time.
Could you append a sequence with the step type in it?
Could you specify what you got in TS 2.x and now what you get in 3.0 for the step name when you insert a new step?
Scott Richardson (NI)
Scott Richardson
https://testeract.com
(2,849 Views)
