NI TestStand
Custom step type
I would like to create a step type which contains the different actions to measure voltage for example.
More generally, I would like to be able to drag and drop a step that measures the voltage where I have to set the input parameters of the voltage to measure. The step will return the result of the test then performed. If you have any idea on how I should go about it, I'm interested.
Message 1 of 1
(619 Views)
