NI TestStand
Customize Toolbar does not save
I customized my toolbar to add the run as seen in the attached image.  When I close TestStand and re-open, it is no longer there.  How do I get this customized toolbar to maintain its settings?
I also tried to use rearrange icons and add that button to the Debug Menu Bar, but that didn't work either.
(3,405 Views)
I am using TestStand 2010 SP1 and was able to add a Second Execution Entry Point by following the directions here. Then when I close TestStand and open it again, the button I added is still there. What version of TestStand are you using? I am assuming you are making this change in the Sequence Editor.
Rohama K.
(3,389 Views)
Lock your UI configuration in the View menu
CTA, CLA, MTFBWY
(3,386 Views)
It was my saved UI configuration since I use a custom UI configuration, I had to save it with the added button on there.
(3,375 Views)
To clarify for other readers. There is a setting in the sequence editor options dialog to always load a UI configuration at startup (rather than restore the settings you had when you last exited). He was likely using this setting.
-Doug
(3,349 Views)
