NI TestStand
Cut And Paste Numerous PreConditions
I'm running a 8186 controller with TestStand 3.0 and CVI 3.0.  My question, is it possible to copy and paste preconditions.  See attached screen print.  Many of my preconditions have over 90 different preconditions.  I'd like to find an expeditious way of copying them.
Tony
(2,941 Views)
Hola,
A way to do is opening the sequence as text (I use Wordpad), locate the step you want to copy the precond from and copy the preconditions.... then paste them to the destination step....
They will look like this..
[SF.Seq[0].Setup[0].TS]
Id = "ID#:xhC9QtHRD0mhQv0DoRz/4C"
PreCond = "PropertyExists(\"FileGlobals.EquipmentUsed\")"
PostExpr = "SetNumElements( FileGlobals.EquipmentUsed, 0)"
Hope this helps,
(2,930 Views)
