NI TestStand
DLL does not export functions necessary for TestStand to pass Cstring data
Hi everyone,
I'm currently trying to export an old DLL from Virtual Studio 2010 to VS 2013. The main problem was to make the program work in UNICODE and not MBCS.
After being able to compil the program, I tried to use it with TestStand. The SW told me to include the 'tsdllparams.cpp' in my repertory to be able to use CString.
However, after doing this, the SW is still telling me that it can't use Cstring (different error message).
Has someone ever faced this?
Thank you.
(2,662 Views)
Hi
You probably should take a look at this document, it could give you some advices
https://www.ni.com/docs/en-US/bundle/teststand-api-reference/page/tsref/string-parameters-c-c-dll-ca...
Do you use Visual Studio only or with Measurement Studio.
What version of TestStand are you using 64bits or 32bits?
Paolo_P
Certified TestStand Architect
Certified LabVIEW Architect
National Instruments France
(2,612 Views)
TestStand does not support Unicode CStrings, which is a different type than a C String
https://www.linkedin.com/in/trentweaver
(2,588 Views)
