NI TestStand
DLL multi instance issue
Hi all & thanks in advance.
I´m trying to load DLLs generated by CVI that it´s calling dinamically/statically(i tryed both) to a DLL.
I call 3 times to different DLLs thats it´s calling to same instrument Dll. when i try run, a Pop-up message return. The problem it´s if i try to run and locate this DLLs on EXE developed by CVI at the same time . Works fine without any problem. So why it´s ocurring this on Test stand?
The DLL for sure it´s fine, due to it´s working on the EXE...
So once i try to run Test stand, the message that shows it's:
Could not load DLL or external library 'C:\NACHO\DLLS\PSA_Driver_CAN_Vector_N1.dll'.
This DLL requires the following DLLs which could not be found or loaded:
api-ms-win-core-heap-l2-1-0.dll (Not Found)
api-ms-win-core-libraryloader-l1-2-0.dll (Not Found)
api-ms-win-core-profile-l1-1-0.dll (Not Found)
api-ms-win-core-processthreads-l1-1-2.dll (Not Found)
api-ms-win-core-sysinfo-l1-2-1.dll (Not Found)
api-ms-win-core-errorhandling-l1-1-1.dll (Not Found)
api-ms-win-gdi-internal-uap-l1-1-0.dll (Not Found)
api-ms-win-core-delayload-l1-1-1.dll (Not Found)
api-ms-win-core-apiquery-l1-1-0.dll (Not Found)
api-ms-win-core-rtlsupport-l1-2-0.dll (Not Found)
api-ms-win-eventing-provider-l1-1-0.dll (Not Found)
api-ms-win-core-processthreads-l1-1-3.dll (Not Found)
api-ms-win-core-registry-l1-1-0.dll (Not Found)
api-ms-win-core-heap-l1-2-0.dll (Not Found)
api-ms-win-core-memory-l1-1-2.dll (Not Found)
api-ms-win-core-enclave-l1-1-0.dll (Not Found)
api-ms-win-core-handle-l1-1-0.dll (Not Found)
api-ms-win-core-synch-l1-2-0.dll (Not Found)
api-ms-win-core-synch-l1-2-1.dll (Not Found)
api-ms-win-core-file-l1-2-1.dll (Not Found)
api-ms-win-core-file-l1-2-2.dll (Not Found)
api-ms-win-core-io-l1-1-1.dll (Not Found)
api-ms-win-core-job-l1-1-0.dll (Not Found)
api-ms-win-core-threadpool-legacy-l1-1-0.dll (Not Found)
api-ms-win-core-threadpool-private-l1-1-0.dll (Not Found)
api-ms-win-core-libraryloader-l1-2-2.dll (Not Found)
api-ms-win-core-libraryloader-l2-1-0.dll (Not Found)
api-ms-win-core-namedpipe-l1-2-2.dll (Not Found)
api-ms-win-core-namedpipe-l1-2-0.dll (Not Found)
api-ms-win-core-datetime-l1-1-1.dll (Not Found)
api-ms-win-core-datetime-l1-1-2.dll (Not Found)
api-ms-win-core-sysinfo-l1-2-3.dll (Not Found)
api-ms-win-core-timezone-l1-1-0.dll (Not Found)
api-ms-win-core-localization-l1-2-1.dll (Not Found)
api-ms-win-core-localization-private-l1-1-0.dll (Not Found)
api-ms-win-core-processsnapshot-l1-1-0.dll (Not Found)
api-ms-win-core-processenvironment-l1-2-0.dll (Not Found)
api-ms-win-core-string-l1-1-0.dll (Not Found)
api-ms-win-core-debug-l1-1-1.dll (Not Found)
api-ms-win-core-errorhandling-l1-1-3.dll (Not Found)
api-ms-win-core-fibers-l1-1-1.dll (Not Found)
api-ms-win-security-base-l1-2-0.dll (Not Found)
api-ms-win-core-comm-l1-1-0.dll (Not Found)
api-ms-win-core-wow64-l1-1-1.dll (Not Found)
api-ms-win-core-wow64-l1-1-0.dll (Not Found)
api-ms-win-core-realtime-l1-1-0.dll (Not Found)
api-ms-win-core-processtopology-l1-2-0.dll (Not Found)
api-ms-win-core-namespace-l1-1-0.dll (Not Found)
api-ms-win-core-file-l2-1-2.dll (Not Found)
api-ms-win-core-file-l2-1-1.dll (Not Found)
api-ms-win-core-xstate-l2-1-0.dll (Not Found)
api-ms-win-core-localization-l2-1-0.dll (Not Found)
api-ms-win-core-normalization-l1-1-0.dll (Not Found)
api-ms-win-core-fibers-l2-1-1.dll (Not Found)
api-ms-win-core-sidebyside-l1-1-0.dll (Not Found)
api-ms-win-core-appcompat-l1-1-1.dll (Not Found)
api-ms-win-core-windowserrorreporting-l1-1-0.dll (Not Found)
api-ms-win-core-console-l1-1-0.dll (Not Found)
api-ms-win-core-console-l2-1-0.dll (Not Found)
api-ms-win-core-psapi-l1-1-0.dll (Not Found)
api-ms-win-core-psapi-ansi-l1-1-0.dll (Not Found)
api-ms-win-security-appcontainer-l1-1-0.dll (Not Found)
api-ms-win-core-util-l1-1-0.dll (Not Found)
api-ms-win-core-threadpool-l1-2-0.dll (Not Found)
api-ms-win-core-registry-l1-1-1.dll (Not Found)
api-ms-win-security-activedirectoryclient-l1-1-0.dll (Not Found)
api-ms-win-eventing-classicprovider-l1-1-0.dll (Not Found)
api-ms-win-devices-config-l1-1-1.dll (Not Found)
api-ms-win-core-kernel32-legacy-l1-1-1.dll (Not Found)
api-ms-win-core-heap-obsolete-l1-1-0.dll (Not Found)
api-ms-win-core-stringansi-l1-1-0.dll (Not Found)
api-ms-win-core-string-obsolete-l1-1-0.dll (Not Found)
api-ms-win-core-kernel32-private-l1-1-1.dll (Not Found)
api-ms-win-mm-time-l1-1-0.dll (Not Found)
api-ms-win-mm-mme-l1-1-0.dll (Not Found)
api-ms-win-mm-misc-l1-1-1.dll (Not Found)
api-ms-win-core-privateprofile-l1-1-1.dll (Not Found)
api-ms-win-core-path-l1-1-0.dll (Not Found)
api-ms-win-core-kernel32-private-l1-1-2.dll (Not Found)
api-ms-win-core-crt-l1-1-0.dll (Not Found)
api-ms-win-core-crt-l2-1-0.dll (Not Found)
api-ms-win-eventing-obsolete-l1-1-0.dll (Not Found)
api-ms-win-core-interlocked-l1-2-0.dll (Not Found)
api-ms-win-security-lsalookup-l1-1-1.dll (Not Found)
api-ms-win-security-lsapolicy-l1-1-0.dll (Not Found)
api-ms-win-core-string-l2-1-0.dll (Not Found)
api-ms-win-core-atoms-l1-1-0.dll (Not Found)
api-ms-win-core-localization-obsolete-l1-3-0.dll (Not Found)
api-ms-win-core-appinit-l1-1-0.dll (Not Found)
api-ms-win-core-com-l1-1-1.dll (Not Found)
api-ms-win-crt-string-l1-1-0.dll (Not Found)
api-ms-win-crt-runtime-l1-1-0.dll (Not Found)
api-ms-win-crt-private-l1-1-0.dll (Not Found)
api-ms-win-core-winrt-error-l1-1-1.dll (Not Found)
api-ms-win-core-com-midlproxystub-l1-1-0.dll (Not Found)
api-ms-win-core-winrt-string-l1-1-0.dll (Not Found)
api-ms-win-security-sddl-l1-1-0.dll (Not Found)
api-ms-win-core-com-private-l1-1-0.dll (Not Found)
api-ms-win-core-com-private-l1-1-1.dll (Not Found)
api-ms-win-core-shlwapi-legacy-l1-1-0.dll (Not Found)
api-ms-win-core-quirks-l1-1-0.dll (Not Found)
api-ms-win-core-psm-key-l1-1-0.dll (Not Found)
api-ms-win-service-management-l1-1-0.dll (Not Found)
api-ms-win-service-winsvc-l1-2-0.dll (Not Found)
api-ms-win-crt-locale-l1-1-0.dll (Not Found)
api-ms-win-core-synch-l1-1-0.dll (Not Found)
api-ms-win-core-processthreads-l1-1-0.dll (Not Found)
api-ms-win-core-sysinfo-l1-2-0.dll (Not Found)
api-ms-win-core-file-l1-1-0.dll (Not Found)
api-ms-win-core-file-l2-1-0.dll (Not Found)
api-ms-win-core-file-l1-2-0.dll (Not Found)
api-ms-win-core-errorhandling-l1-1-0.dll (Not Found)
api-ms-win-core-localization-l1-2-0.dll (Not Found)
api-ms-win-core-rtlsupport-l1-1-0.dll (Not Found)
api-ms-win-core-processthreads-l1-1-1.dll (Not Found)
api-ms-win-core-debug-l1-1-0.dll (Not Found)
api-ms-win-core-sysinfo-l1-1-0.dll (Not Found)
api-ms-win-core-libraryloader-l1-1-0.dll (Not Found)
api-ms-win-core-interlocked-l1-1-0.dll (Not Found)
api-ms-win-eventing-controller-l1-1-0.dll (Not Found)
api-ms-win-eventing-consumer-l1-1-0.dll (Not Found)
api-ms-win-service-core-l1-1-1.dll (Not Found)
api-ms-win-service-core-l1-1-2.dll (Not Found)
api-ms-win-service-management-l2-1-0.dll (Not Found)
api-ms-win-service-private-l1-1-2.dll (Not Found)
api-ms-win-service-private-l1-1-1.dll (Not Found)
api-ms-win-security-base-private-l1-1-1.dll (Not Found)
api-ms-win-security-audit-l1-1-1.dll (Not Found)
api-ms-win-core-perfcounters-l1-1-0.dll (Not Found)
api-ms-win-core-string-l2-1-1.dll (Not Found)
api-ms-win-core-localization-l1-2-2.dll (Not Found)
api-ms-win-core-version-l1-1-0.dll (Not Found)
api-ms-win-core-shlwapi-obsolete-l1-2-0.dll (Not Found)
api-ms-win-core-kernel32-legacy-l1-1-5.dll (Not Found)
api-ms-win-core-url-l1-1-0.dll (Not Found)
api-ms-win-core-registryuserspecific-l1-1-0.dll (Not Found)
api-ms-win-storage-exports-internal-l1-1-0.dll (Not Found)
api-ms-win-storage-exports-external-l1-1-0.dll (Not Found)
api-ms-win-shell-shellcom-l1-1-0.dll (Not Found)
api-ms-win-shell-shellfolders-l1-1-0.dll (Not Found)
api-ms-win-core-job-l2-1-0.dll (Not Found)
api-ms-win-security-capability-l1-1-0.dll (Not Found)
api-ms-win-core-versionansi-l1-1-0.dll (Not Found)
api-ms-win-core-version-l1-1-1.dll (Not Found)
api-ms-win-core-versionansi-l1-1-1.dll (Not Found)
api-ms-win-core-version-private-l1-1-0.dll (Not Found)
(3,714 Views)
Hi, I got into the same issue for a different .dll file.
Did you find a solution ?
(2,854 Views)
Hi, nothing new.
Just note,at least under my experience, with Teststand 2010 you cannot instantiate just only one time this dll, more than 1 make error. In case you use est stand 2017 you can instantiate up to 2 dll, more than 2 you find error.
The final solution was make 1 DLL+ 1 Exe(socket client + socket server), you instantiate on test stand the Client(dummy dll only run at strart the Exe & send parameters)  to the server, where  you instantiate the Original DLL.
By this way you can instantiate N times the DLL under conflict.
(2,843 Views)
