NI TestStand
DLL parameter usage
We would like to create some C library which several predefine paramaters (ex: frequency: 16Mhz, 24Mhz, etc...).
We would like to be able to create a DLL from this code and call it from TEst Stand.
Target is to allow user calling this library to set one paramater among several choice pre-defined and allowed.
Could you please help us identifying the right procedure for such a thing?
At this time we can only update paramter by setting directly value or text.
Thanks in advance for your help.
David
(3,146 Views)
Hi David
There are serval examples in Teststand Programm folder.
I would recommend you take a look into the ....\National Instruments\TestStand 4.0\Examples\Demo\C
and use the computer.seq  This is the "HelloWorld" stuff in TestStand
Hope this helps
Greetings
Juergen
--Signature--
Sessions NI-Week 2017 2016
Feedback or kudos are welcome
(3,145 Views)
