NI TestStand
DataSource visible in Flow properties
Hi.
Is there anyway that I can show the expression Step.Datasource in the column "Flow Properties" in the editor.
If you for instance inserts a "Post Expression", then you can see that afterwards in Flow Properties... and if you stop the mouse cursor on that spot, then it show you the expression..... but you cant see that with DataSource... is there anyway to make that working????
(3,244 Views)
Bojer,
It is not possible to modify what TestStand displays under the "Flow Properties" column.
I assume that you want to be able to see your Data Source at execution time.
You could accomplish this by creating a custom step type that takes "Step.DataSource" as the Step Description Expression.
In that way you would see the Data Source under the description column at execution time.
Hope it Helps.
If you have any question let me know.
Antonio Lie.
(3,221 Views)
Hi Antonio.
It's actual at editor mode I want to be able to see step.datasource... just like you see a lot of others settings, for instance locks, preexpression and conditions in the "flow properties" column.
So the question was more a improvement for later releases....
Kind regards Thomas
(3,180 Views)
