NI TestStand
Database Schema
Hi, can someone post here the Database schema of Teststand pls?
I need to know the relational model, the table names.
I need the standard database, the one with UUT_RESULT, STEPS, and the PROPERTY tables.
If you have a SQL script to create it on SQL Server it would be the best
thanks
(1,628 Views)
Here is the generic record set.
Hopefully it is the one you wanted. 🙂
(Change .txt back to .sql)
(1,515 Views)
