NI TestStand
DatabaseOptions Callback
We are trying to use the DatabaseOptions callback from within Teststand this way multiple databases may be accessed from different sequence files.  I read the forum discussion 2V39NFO6 which is the same exact problem I am having.  We followed the instructions carefully.  However, when "Disable database logging" is enabled from the station configuration, the callback does not appear to modify the database options (changing "Disable database logging" to True).  The connection string we are using is specified in an expression as:
Parameters.DatabaseOptions.ConnectionString =
"Provider=MSDASQL.1;Persist Security Info=False;User ID=psgest1;Data Source=myodbc;Extended Properties='DATABASE=xxxxxx;
DSN=myodbc;OPTION=H,í;PORT=0;UID=xxxxxx'"
Using this connection string outside of the callback, it works and data is written to the database fine...any ideas?
Adam
(4,290 Views)
Are your quotes (") balanced?
Regards
Ray Farmer
Regards
Ray Farmer
(4,280 Views)
I have two double quotes and two single quotes, so I would *think* they are.
When I use the connection string in the global database options dialog it seems to work fine.
It is only when I use the DatabaseOptions callback that it appears to have no effect.
(4,277 Views)
Put a breakpoint at the point before setting the parameter and then compare the values received from the dialog setup to what you are setting it to.
Regards
Ray Farmer
Regards
Ray Farmer
(4,272 Views)
