NI TestStand
Date Custom Data Type
I am trying to read in a date (mm/dd/yyyy) in string form from a file and then pass that into a LabView VI that uses that date to delete files by. However I cannot find a way to read that date in and store it in TestStand. Is there an easy way to read in the date, store it in a local variable and then pass that variable into my VI which uses it as a Timestamp?
Chris
(3,776 Views)
you can store the date in a string local variable, or a numeric local variable. (TestStand and LabVIEW do not use the same timing convention (since 1907 vs 1904) as far as I'm aware)
regards
Rodéric L
Certified LabVIEW Architect
(3,775 Views)
I read it in from the file as a string and that is fine it is stored in my local variable correctly but when i try to pass that into teststand in the formal mm/dd/yyyy format it returns a random date usually around 1903
(3,768 Views)
I think Roderic is trying to get you to do it like this:
Read date data in VI
Convert date data to string in VI
Pass string to TestStand
TestStand passes string to another VI
VI converts string to date
CTA, CLA, MTFBWY
(3,766 Views)
