NI TestStand
Deactivate Error Banner/Dialog
One method I know is to modify the Sequential Model, but I read it's not reccomendable. I did it by adding one more Precondition.
Is there a way to not show it without modifying the Sequential Model?
Thank you.
Regards.
Aldhair Garza
My Channel: https://www.youtube.com/@LV_Lab
(3,584 Views)
Why not in sequential mode? Any Specific reason for "not recommended"?
Check for Error Code, Bypass those errors alone.
Palanivel Thiruvenkadam | பழனிவேல் திருவெங்கடம்
LabVIEW™ Champion |Certified LabVIEW™ Architect |Certified TestStand Developer
Kidlin's Law -If you can write the problem down clearly then the matter is half solved.
(3,566 Views)
Accepted by topic author AldhairGarza
Hi Aldhair,
I'd suggest using sequence file callbacks.
You could catch and handle the error using "SequenceFilePostStepRuntimeError", but as I don't understand the entirety of what you're trying to achieve, the following steps should hide the Error Banner:
(1). Add the "PostUUT" sequence file callback to your sequence file.
(2). Add a statement expression in the Setup group:
(3). Set the statement pre-condition to:
Parameters.Result.Status == "Error"
(4). Set the statement post-expression:
Parameters.ModelPluginConfiguration.RuntimeVariables.ModelDialogsEnabled.SequentialShowStatus = False
I hope this helps,
Charlie
Charlie Rodway | Principal Software Engineer | Certified TestStand Architect (CTA)
Computer Controlled Solutions Ltd | NI Silver Alliance Partner | GDevCon#1 Sponsor
(3,560 Views)
Hi, thanks for answering.
That's what I actually did.
I added the PostUUT Sequence Callback but I modified the Preeconditions instead but I think your method is better and more simple.
(3,555 Views)
No problem - glad I could help!
Charlie
(3,552 Views)
