NI TestStand
Default Post actions in custom step
I know that it's impossible to select from the fields "On pass" or "On fail" in the "post actions" in a custom step (it's possible for a step in a sequence but not in a custom step), under TestStand 3.0, it's "dimmed".
Example : you can't select "goto destination" in "default post actions" directly in your type palette.
Does TestStand 3.1 include any improvement about this point?
Thank You.
(3,032 Views)
Hello Breizh,
Yes ,you can with TestStand 3.1 define your own default post actions.
You can set goto destination and define your destination with an expression.
Hope this helps.
Regards
Salissou ISSA
Applications Engineering
NI France
(3,021 Views)
