NI TestStand
Default new sequence file template
Dear collegues,
I am using a custom process model based on the TestStand default sequential model.
Now I had to add some parameter to the MainSequence prototype. When I create a new sequence file within in the Teststand-IDE the file contains the MainSequence callback withput any Parameter. The Test Developer has to remove it and add the sequennce file Callback "MainSequence". I would like to avoid this, since if the developer forgets to do this, he has to add the parameter by hand. Furthermore callback parameter are positional, so the developer has to put them in the right order and I would like to force the developer to overwrite the parameter "SetTestKey", which was also defined in my custom process model.
For this reason I would like to change the sequencefile that will be loaded, when I select "new sequence file" in the IDE.
Is there a template for new sequence files I can customize?
Thank you in advance.
Message 1 of 1
(1,115 Views)
