NI TestStand
Define variable with void data type.
I would like to define a variable and a structure with void data type.
How could I define it?
regards.
(5,268 Views)
Hi Labview_Vish,
TestStand doesn't have any void data type defined. But what exactly are you using this for?
Hope to hear back
SijinK
(5,257 Views)
HI SijinK,
Thanks for the reply.
I want to call some "dll" in the TestStand. In this "dll", function requires some variable of void data type as input.
e.g.  dll - Test.dll
Function  - short int Func_a (void var_a, long var_b, void *var_c, custom_struc *var_d)
I want to call this function in the TestStand. Using "C/C++ Dll" adapter module and "Action" step type, I will call this dll and its function.
For passing values to this function, I need to define some variable with respective data type.
Please let me know how could I do this.
Regards.
(5,251 Views)
HI labview_vish,
You would have to pass the void and the void * parameters as integers from TestStand. This has worked for me before. Please let me know how things went when you tried this.
SijinK
(5,237 Views)
In C, the void* data type is used as a generic pointer to memory.  This is generally used for functions like malloc that have no way of knowing what the contents are of the memory you would like to use.  In order to correctly pass information to your DLL, you need to know more about the function you are calling.  This parameter could really refer to anything.  Is it supposed to be an input parameter or an output parameter or both?  Is it supposed to be a single value or an array of values?  Perhaps it's type is supposed to be specified by another parameter to the same function.  In any case you will need to edit the prototype directly in TestStand and give it the appropriate type for your application.
--Peter
(5,219 Views)
Thank you, Peter and SijinK.
Currently I can define the Void or Void* as interger and it work for me. But in future I might need to define as the specific datatype as mentioned by Peter.
(5,200 Views)
Peter is right "In any case you will need to edit the prototype directly in TestStand and give it the appropriate type for your application". Also take a look at this KnowledgeBase
Kind regards
Heinz
(4,521 Views)
