NI TestStand
Deploy Library Error
I am using teststand 4.1 i am getting an error on the deploy library step. Please find the snapshot attached for reference.
I am not able to understand the error, please help . I am having a full professional development license.
Regards
Amit
(3,138 Views)
Amit,
Are you using LabVIEW 8.6?
Did you install LabVIEW 8.6 before you installed TestStand 4.1?
If so you need to install "Remote Execution Support for NI TestStand"  from your LabVIEW 8.6 CD.
"Remote Execution Support for NI TestStand" feature is not installed on the machine if LabVIEW's installer does not detect TestStand on that machine.
Regards
Anand Jain
(3,126 Views)
Hi Anand
Thanks For the solution, it worked.Smiley Happy
Regards
Amit
(3,115 Views)
