NI TestStand
Deploy Teststand System then it did not working.
i was already packaged a teststand sequence,but it did not work in the other PC which was setup the Testand 4.2.1 and Deploy Teststand System !
Error is as follows:Error.png
Message 1 of 8
(4,425 Views)
My guess is your search directories aren't set up correctly.  All code modules have to be reachable by your search directories.
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
Message 2 of 8
(4,422 Views)
Make sure you have all dependancies loaded on the other system, such as hardware drivers.
Regards
Ray Farmer
Message 3 of 8
(4,416 Views)
Thanks all !
i had solved it. but i had the another question. i
the error code :
Error: The following VIs or Project Libraries have duplicate names
You must change the names or add them to project libraries:
C:\Windows\System32\user32.dll while Processing VIs...
how can i do for it?
Message 4 of 8
(4,413 Views)
Jack,
Generally different questions should go in a different thread so that when people browse and search the forums they know that one thread is only tied to one issue.
Do you have two copies of user32.dll running around?  That's what it sounds like.  Otherwise you have 2 VIs named the same thing.
Is this during deployment?  Like when you build the deployment?
jigg
CTA, CLA
testeract.com
Message 5 of 8
(4,398 Views)
i like that only have a Vi which was used of the User32.dll,waitting for a moment ,i will check it!
thanks for your help!
Message 6 of 8
(4,392 Views)
if i did't select the "Deploy files in testtand public directories" checked then it will not display the error!
why???
Message 7 of 8
(4,385 Views)
Are you trying to deploy user32.dll?  Normally you wouldn't need to deploy it since it is a Windows dll.  I believe it is unchecked by default for including in a deployment.  Can you try unchecking it and seeing if the problem goes away?
It shows up when you deploy the TS Public directories because something inside of there is calling into it.
Message 8 of 8
(4,373 Views)
