I have difficulties to understand the creation of a MSI installer for deploying sequences both as a full build or a patch installer. In particular I have a structure like this:
I’m using TestStand 2022 and LabVIEW 2019. When I first installed the complete deploy package on the target machine the dependencies related to LabVIEW 2019 were not seen even if the Adapters in TestStand was correctly configured and detected that version without problem.
Then I have changed the .seq file and updated the lvlib and I have created a patch installer but when I have run the sequence I have found that on the target machine only the .seq file even if the source tree of the Distributed Files shows all the correct files selected.
I have checked “From TestStand Public Directory” and “From TestStand Configuration Directory” options but still building patches that only updated the .seq files. What am I missing?
Thank you for the help!
Best Regards,
Zuc
