NI TestStand
Deployed TS application has dimmed run function
I have developt TS application with Labview modules and Labview Operator Interface with TS API controls.
On my computer it works normally.
On target computer (both PC&WinXT) application has grayed entry point buttons and it is impossible to run any sequence.
This computer is clear machine with clear system with same architecture as development PC.
I have licenses activated on target computer (see attachment) which according my opinion enough to simply run tests.
I have tryed to place on target computer operator interface from TS demo set and opened sequences from TS examples...
I watched same picture: all buttons to run TS model entrypoints are grayed.
I have tryed to use TS API and call execurion entry point manually.
I had error message: Index out range.
That means there are no any accessible entry points.
We have SOP very near and I want understand: may by some license inaccessible to run test?
But after cafuly reading all license descriptions I has opinion: everything should work.
What have I to check additionally?
Many thanks in advance for any assistance.
(3,074 Views)
Accepted by topic author anpis
If you have the full-featured UI, with the menu options try the following on the target machine.
Configure->Station Options. Select the Model tab.
Verify the Station Model in the file path is correct.
I have noticed that if TestStand does not find a valid 'Process Model' both Test UUTs and Single Pass will be grayed out.
PH
(3,063 Views)
Thanks a lot!
It was a real reason.
Now everything is OK/
(3,041 Views)
