NI TestStand
Deployed file is not writeable
I have an issue where my deployed test system is deploying a ASCII file (TCL script) that is supposed to get dynamically edited by a LabVIEW VI durring test.  The issue is that Windows 7 is not allowing this file to be edited because if its security setting and where it is deployed to (the program files directory).  Is there a way to deploy this file so I don't have to go find it after install and edit the security on the file post deploy?  I think LabVIEW application builder has some checkbox to do this, does TestStand have the same thing?
As a side note, I thought I could just deploy this file to a different directory but I am not satisfied with TestStand's choses of Installation Directories.  I think that it is missing the option to deploy to the ProgramData directory.
Paul
(3,092 Views)
I agree 100% that it would be nice to have the Program Data folder as an option in the TestStand folder. ( maybe fill out an Idea Exchange)
We put our writable files in the Application Data folder: TestStand Data Application Directory
Then under there I will have the deployment utility create a folder that is specific for the Workspace I am deploying.
The sucky thing is that you have to have your search directories point to it.
Another option is to set C: as your base and then you can build off of it in your distribution list.
Hope this helps,
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(3,084 Views)
