NI TestStand
Deploying testexec.ini
All,
I've got a custom OI and process model that I am trying to transfer over to another computer, to do this I've created a LabVIEW installer from 3 source distributions and one application.  I went with 3 source distributions because each goes to a different path.
The 3 source distributions are as follows:
- Source vis
- process model
- config files (StationGlobals.ini, Users.ini and TestExec.ini)
My struggle enters the scene when I try and specify what process model I want to be used.  My plan was to do this by transferring TestExec.ini to C:\ProgramData\National Instruments\TestStand 2012\Cfg and hoping that TestStand took the changes; well TestStand does not seem to load the correct TestExec.ini, so my questions are as follows:
- Is there a better way to specify what process model I want TestStand to use?
- I do not delete the old config files from C:\ProgramData\National Instruments\TestStand 2012\Cfg, does that cause me a problem to write over them?
Bill
John 3:16
(3,728 Views)
(3,718 Views)
