NI TestStand
Deployment Error for TS 3.5
I am trying to get the base deployment for the testStand engine and the base testStand system. In my deployment I am including the component/user directory. I have mass compiled it to LV 8.0. I am getting the following error with lots of other warning.
Error: The following file(s) could not be copied:
C:\Program Files\National Instruments\TestStand 3.5\Components\User\RuntimeServers\LabVIEW\Server.llb\TestStand Server - Not a Window Refnum
C:\Program Files\National Instruments\TestStand 3.5\Components\User\RuntimeServers\LabVIEW\Server.llb\TestStand Server - Window Refnum
Thank you,
Hiren
Hiren Patel
(3,059 Views)
Howdy Hiran -
If you have not intentionally modified the LabVIEW runtime server, I would recommend copying the original server from your "NI" to your "User" directoy.  Overwrite the C:\Program Files\National Instruments\TestStand 3.5\Components\User\RuntimeServers\LabVIEW folder with C:\Program Files\National Instruments\TestStand 3.5\Components\NI\RuntimeServers\LabVIEW.
Let me know if you still see the error after overwritting the runtime server with the original.
Andrew W || Applications Engineer
(3,041 Views)
