NI TestStand
Deployment Path confusion
Can I deploy a .Net-binary used by my sequence into indepentent directory from my Workspace, Project and Sequence File? I mean without adding the search path for the binary after the first start.
I used the Deploment Utility and tried combinations like:
"TestStand Public Documents" as destination for TestStand files.
"Installation Directory" as destination for .Net binary.
After deployment the sequence wont´t find the executable.
I think the separate documents, scripts and executables makes sense as it is common with Windows 7. But with the currents Deployment Tool I end up putting everything in on folder. Otherwise it won´t work on the target.
(3,580 Views)
Probably my question is:
How can I delopy search paths?
Or more precise
How can I add my Install path as search path to my current Sequence/Project/Workspace?
(3,579 Views)
Hi jojp,,
the search directories are stored in teh TestExec.ini file.
How do I Include My Station Globals, Search Directories, Tools Menu, etc. in My Deployment When Using the TestStand Deployment Utility?
http://digital.ni.com/public.nsf/allkb/E5E4FEADEFE6023D862571590000C5CC?OpenDocument
Best regards
Andrea
(3,573 Views)
Vielen Dank Herr Perin, das nächste Mal rufe ich Sie am besten gleich an 🙂
(3,545 Views)
