NI TestStand
Deployment Utility - Malfunctional installer being created
Hi all,
I'm having an issue with the Deployment Utility.
After finally resolving all "problems" in our code the Deployment Utility finally allowed for the installer to be built.
But when executing the installer (which is meant to contain all packages and install them with no user choice) right after the start an error message appears claiming at least one "NI-DCPower Runtime" needs to be installed.
When double-checking the chosen packets the DCPower V19.5 is selected. Just in case something was missed out, the checkbox "Automatically Include Required Installers" was ticked. Unfortunately this didn't solve the situation.
A search for the runtime of DCPower didn't turn up any result.
Can anyone explain this behaviour or, preferred, offer a solution for this?
Best regards
J. Ludwig
(1,946 Views)
 Hi all,
I made two screenshots that show the selected packages (some of them) as well as the error message:
Any hint appreciated.
Best regards
J. Ludwig
(1,892 Views)
