10-26-2017 08:22 AM
I am trying to build a TestStand Deployment with TestStand Runtime.
When I go to build the log shows "Finished Installer Build" then It says Finished Deployment Build in red with a red X, then Aborted, but no errors.
Some things in the TSDU Installer Build Log.txt file:
1. Under MDF modules, for NIMdf.dll [MODULE NOT FOUND]
2. Also get: >> Error: Failed to merge Row: CustomAction into Table: _Validation
Any ideas?
10-27-2017 06:07 PM
Are you able to locate NIMdf.dll on your computer?
I found mine in the following path:
C:\Program Files (x86)\National Instruments\TestStand 2016\Components\Tools\Deployment Utility\data
