NI TestStand
Deployment Utility copies my MAX configuration to the target system
I am creating an Installer for TestStand 3.5 and I have found that my MAX device configuration is carried to the target system.  How can I prevent the installer from coping this configuration to the target system?  My Labview VIs use VISA 4.1 to access Serial Ports.
(3,059 Views)
Hello goldee,
In the TestStand Deployment Utility, select the Installer Options tab, and then click the Drivers and Components... button.  Make sure the Include Hardware Configuration from Measurement & Automation Explorer checkbox is unchecked.
Let me know if that fixes it or not.
Kristen
(3,038 Views)
Yes, That fixes my problem- Thanks
(2,985 Views)
