I'm doing my first deployment and have few questions:
1) I tried to deploy ONLY the TS user directories. I checked the 'Deploy Files in TestStand User Directories' option and did not check 'Install TestStand Engine' since I deploy it into a system with TS3.0+CVI7.0 software(same as the source).
The process was successful by I get the following warnings in the log file.
Starting Log.
Building...
5:47 PM
An installer is being created.
The installer is finished
The build process is done.
5:48 PM
Warning: You may need to add any sequence files referenced by the following expressions:
"reportgen_" + RunState.Root.Locals.ReportOptions.Format + ".seq" in step 'Process Step Result', sequence 'SequenceFilePostResultListEntry', sequence file 'C:\Program Files\National Instruments\TestStand 3.0\Components\User\Models\TELRAD_SequentialModel.seq'
"reportgen_" + RunState.Root.Locals.ReportOptions.Format + ".seq" in step 'Process Step Result', sequence 'ProcessModelPostResultListEntry', sequence file 'C:\Program Files\National Instruments\TestStand 3.0\Components\User\Models\TELRAD_SequentialModel.seq'
"ReportGen_" + Parameters.ReportOptions.Format + ".seq" in step 'Get Report Footer', sequence 'TestReport', sequence file 'C:\Program Files\National Instruments\TestStand 3.0\Components\User\Models\TELRAD_SequentialModel.seq'
"ReportGen_" + Parameters.ReportOptions.Format + ".seq" in step 'Get Report Header', sequence 'TestReport', sequence file 'C:\Program Files\National Instruments\TestStand 3.0\Components\User\Models\TELRAD_SequentialModel.seq'
"ReportGen_" + Parameters.ReportOptions.Format + ".seq" in step 'Get Report Body (Sequence)', sequence 'TestReport', sequence file 'C:\Program Files\National Instruments\TestStand 3.0\Components\User\Models\TELRAD_SequentialModel.seq'
"ReportGen_" + Parameters.ReportOptions.Format + ".seq" in step 'Set Report Disabled Message', sequence 'TestReport', sequence file 'C:\Program Files\National Instruments\TestStand 3.0\Components\User\Models\TELRAD_SequentialModel.seq'
RunState.ProcessModelClient in step 'MainSequence Callback', sequence 'Single Pass', sequence file 'C:\Program Files\National Instruments\TestStand 3.0\Components\User\Models\TELRAD_SequentialModel.seq'
RunState.ProcessModelClient in step 'MainSequence Callback', sequence 'Test UUTs', sequence file 'C:\Program Files\National Instruments\TestStand 3.0\Components\User\Models\TELRAD_SequentialModel.seq'
What does it mean? What to do about it?
2) The utility does not include the cfg/TypePalettes where I have a my own file.
Is there a reason to it? Do I need to include it manually?
3) When I included workspace in the utility I get the following errors:
Starting Log.
Processing Workspace...
Done processing workspace file
Building...
6:08 PM
Error could not open LabVIEW
Distributing VIs requires the LabVIEW Development System
Class not registered
in TestStand - Get LV Reference.vi->TestStand - Package VIs.vi->TestStand - Build.vi->TestStand - Distribution Wizard GUI.vi->TestStand - Deployment Utility Splash Screen.vi
An installer was not created due to an error
6:08 PM
Error Code:-2147221164
In order to eliminate the problem source I un-checked the files presented by the 'Analyze Source Files' until all of them are un-checked. Even in that case I get the error message.
What does the message mean?
I don't use any LV in my system!!!!!
Thanks and my apology for the long message
Rafi
