NI TestStand
Deployment analysis error
We made sure all of addressing was relative and changed the directory name of our code to conform to our ClearCase naming conventions. I load the ws file and the main sequence after which the tests come up and run normally. However we are having build problems. When running analysis from the Distributed Files tab I get the following warnings and error.
Any suggestions?
Warning: This problem will cause an error when building a deployable image or an installer. The following file(s) were not found:
Dialogs\PreUutIF.vi in step 'Get UUT Information', sequence 'PreUUT', sequence file 'C:\__views\calTest_jhite\mastrv\automated_tests\MastrvCalAndTest\TestStand\MASTRV-CalAndTest.seq'
MASTRVCalAndTest.vi in step 'Initialize System', sequence 'PreUUTLoop', sequence file 'C:\__views\calTest_jhite\mastrv\automated_tests\MastrvCalAndTest\TestStand\MASTRV-CalAndTest.seq'
Transmitter\MvTransmitter.vi in step 'Power Up TX', sequence 'txPowerUp', sequence file 'C:\__views\calTest_jhite\mastrv\automated_tests\MastrvCalAndTest\TestStand\MVTX.seq'
Traffic Controller\MvTrafficController.vi in step 'Power Up TC', sequence 'tcPowerUp', sequence file 'C:\__views\calTest_jhite\mastrv\automated_tests\MastrvCalAndTest\TestStand\MVTC.seq'
Switch\MvSwitch.vi in step 'Power Up SW', sequence 'swPowerUp', sequence file 'C:\__views\calTest_jhite\mastrv\automated_tests\MastrvCalAndTest\TestStand\MVSW.seq'
Receiver\MvReceiver.vi in step 'Power Up RX', sequence 'rxPowerUp', sequence file 'C:\__views\calTest_jhite\mastrv\automated_tests\MastrvCalAndTest\TestStand\MVRX.seq'
Linearizer PA\MvLinearizerPA.vi in step 'Power Up LN', sequence 'lnPowerUp', sequence file 'C:\__views\calTest_jhite\mastrv\automated_tests\MastrvCalAndTest\TestStand\MVLN.seq'
Baseband Processor\MvBasebandProcessor.vi in step 'Power Up BB', sequence 'bbPowerUp', sequence file 'C:\__views\calTest_jhite\mastrv\automated_tests\MastrvCalAndTest\TestStand\MVBB.seq'
Dialogs\DirectionsIF.vi in step 'Connection Instructions', sequence 'bbPowerUp', sequence file 'C:\__views\calTest_jhite\mastrv\automated_tests\MastrvCalAndTest\TestStand\MVBB.seq'
Report\MvReportIF.vi in step 'Reset Report', sequence 'EA-555005-001', sequence file 'C:\__views\calTest_jhite\mastrv\automated_tests\MastrvCalAndTest\TestStand\MVBB.seq'
An Error Has Occurred
Error Code:1
Invoke Node in TestStand - Match Visisble and Selected Items in Tree View.vi->TestStand - Update LV Tree View.vi->TestStand - Distribution Wizard GUI.vi->TestStand - Deployment Utility Splash Screen.vi
(3,071 Views)
Please have a look of this link : http://forums.ni.com/ni/board/message?board.id=330&message.id=19046&requireLogin=False
Hope this gives you some idea of solving your issue.
(3,062 Views)
