NI TestStand
Dequeue a teststand queue with labview
I'm trying to dequeue elements since a VI that is running in a Thread independent of the mainsequence (Teststand).
I :
1.- Create a Queue.
2.- Launch the VI in a new trhead (Is a states machine controlated by the queue ).
3.- Now in TESTStand mainsequence i will like enqueue elements to give orders at VI. Any idea how to do this?
egards,
Oriol
(4,061 Views)
In TestStand you call a VI that is a wrapper for Enqueue FIFO element. (FGV so you have the FIFO reference in a shift register)
Rodéric L
Certified LabVIEW Architect
(4,056 Views)
Using queues only with labview The "Dequeue" function is in standby waiting 2 possible events:
1.- Element to dequeue in the queue --> Return the queue element.
2.- The queue is closed --> Return Error.
Using a "Reference Object" I don't find how to do this.
(4,055 Views)
Thxs roderic,
The problem is in the labview part.... I don't find a easy way to do the dequeue.
Regards
Oriol
(4,053 Views)
First, the best way is to enqueue a close message so you know it has to close.
Second, it returns an error when the queue ref is destroyed =>you just need to handle the error! Maybe the easiest way would be to add a failure post step action to your step (in TestStand) and do whatever exit code you need to perform!
BR,
Rodéric L
(4,034 Views)
