NI TestStand
Details on continuity test.
Continuity test:
While doing continuity test i.e assume a DUT with 12 pins and 2 supply pins. I am doing continuity test separately for each pin, Why should we ground the remaining pins other than supply, Gnd and adjacent pins of a DUT under test while checking continuity.  Because in the case of short circuit detection adjacent pins are enough. Is there anything that any pin might be shorted with other pins irrespective of location.
(3,044 Views)
There is an NI STS Tech Support group that would be a better board for this question. You need to request access to join.
https://www.linkedin.com/in/trentweaver
(3,015 Views)
