NI TestStand
Detecting if a step is a sequence call
I am using the SequenceFilePostStepFailure callback to pop up custom messages to an operator, but I don't want to do this when the step being serviced is a sequence call. Is there some way to determine in the callback just what type of step is being serviced?
Dave
(5,013 Views)
RunState.CallingStep.AdapterKeyName == "Sequence Adapter"
Hope this helps,
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(5,008 Views)
Jigg,
I've put a breakpoint in my callback to see if I can spot that variable during runtime and I can only get to RunState.CallingStep. The AdapterKeyName property doesn't appear. Under RunState.CallingStep I get several more subcategories (TS and Result) but that property doesn't appear there either.  Any hints as to what I am missing?
Dave
(5,000 Views)
I just located it in Watch View expression builder.  These properties are powerful, but boy are they obscure. Sorry for the bad info and thanks for the tip.
(4,999 Views)
Glad you found it.
You can also look to see if the Parameters.Result.TS.SequenceCall property exists.
jigg
CTA, CLA
testeract.com
(4,991 Views)
