NI TestStand
Determing the file which called a sequence....
(3,012 Views)
Sorry, Pressed enter to quickly....
So heres he question...
MainSequence in "Sequence_1a.Seq" runs the step "SequenceCall", which calls a sequence called "DoSomething" in "SequenceFile_2a.Seq". Nice and easy so far....
Now, the "DoSomething" Sequence needs to call a sequence which is in "Sequence1_1a.Seq"......But, the sequence file name, can't be hard coded because the there are multiple versions of the file "Sequence_1a.Seq" (eg. "Sequence_1b.Seq").
So how can "Sequence_2a.Seq" determine the file name of the sequence that called it?
Now I know one solution is to pass a parameter into "Sequence_2a.Seq" with the relevent info in it(Possibly the best way). But the files have already been written and it would be a long task to change everything to include parameters and the handling for it.
Is there a way using the API to determine the sequence filename of the caller to the "DoSomething" Sequence...?
Any help would be appriciated...
(3,009 Views)
Hi!
You can find out the path of the sequence file that called a sequence in another sequence file by using the following property path in the called sequence: "RunState.Caller.RunState.SequenceFile.Path"
I hope this helps.
Good Luck!
Marcela
(3,000 Views)
