NI TestStand
Differences between TestExec and Sequence Editor for LabView7.1 runtime?
My sequence runs perfectly in the Sequence Editor using the LabVIEW 7.1 runtime engine adapter and the dev adapter.
However when I try it using full featured TestExec.exe (the supplied LabVIEW user interface) it gives the common
'VI is not executable' error for one of the steps if I have the runtime adapter chosen.
It works when the dev adapter is selected.
The step that gives the error has no broken arrow - and as I mentioned,
it works in the Sequence Editor with the same runtime engine adapter.
The search paths are identical.
Is there anything special I should know about TestExec.exe?
I am at a loss on this one - any ideas?
TestStand 4.2.1, LabVIEW 2009, LabWindows/CVI 2009
(3,234 Views)
Hi believer,
I think you have to rebuild the testexec.exe with labview 7.1.
Copy the NI folders to the User folder. You will find all the source VI's and the build file for the application builder as part of the file set.
Regards
Ray Farmer
Regards
Ray Farmer
(3,221 Views)
Thanks Ray - that was it.
(3,206 Views)
