NI TestStand
Differnet Station Global files
I am using TestStand 2010.
I am having a scenario where I have two releases which are having different station globals. I see teststand default reads the station globals from a standard location. Is there a way to read the station gloabls from different locations for both the releases or with different file names so that i can have both the releases in the setup without disturbing the other.
regards,
Ramjee V
(3,068 Views)
The only cfg file that can be in a different location is the Users.ini from what I understand.  Sounds like the way to go is to use FileGlobals if the settings are specific to a file.
This is the very reason I hate Station Globals.
Ideally what you should do is use FileGlobals and then store the information into property files.
However, if this is not an option then you could add more station globals with different names for your new automations.
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(3,066 Views)
