NI TestStand
Disable SequenceFileLoad
Hi, I am writing a custom UI application using TS 4.1 and LV 8.5.1.
I would like to have the possibility to disable the execution of the SequenceFileLoad/SequenceFileUnload of the model when starting/exiting the application. I searched the help and forums, but did not find anything. Does anybody have an idea how to achive this?
Thanks, Zoli
(3,194 Views)
when you call GetSequenceFileEx use the option GetSeqFile_DoNotRunLoadCallback which will stop the SequenceFileLoad
Regards
Ray Farmer
(3,190 Views)
Hi Ray.
Yes, this is OK when opening a sequence file with the Engine. But the model is loaded automatically at startup.
I did some more digging and came to the conclusion that I can disable the use of a model. So I used IEngine.StationOptions.UseStationModel = False.
But anyway it would be nice if this could be easily achieved also with ApplicationMgr options.
Greetings, Zoli
(3,187 Views)
