NI TestStand
Disable all model plugins in the sequence
Hi all,
I want to disable not only report generation but also all others plugins (report or database) at runtime.
In "ReportOptions" callback, I'm using this expression : Parameters.ReportOptions.DisableReportGeneration = True
This expression disable NI report generation (NI_ReportGenerator.seq) but it doesn't disable my own model plugin.
I tried to add in expression : Parameters.ModelPlugin.Base.Enabled = False
But it's not working
How can I do?
Thanks for your help
(3,566 Views)
I threw together a quick example. Basically you should override the ModelPluginConfiguration callback and iterate on Parameters.ModelPluginConfiguration.Plugins
You are right in setting Base.Enabled to False.
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(3,526 Views)
Sorry,  but i don t want to disable manually during plugin configuration.
I want to disable at the sequence startup.
(3,517 Views)
Did you look at my example?????
Maybe I'm not sure what you mean by "sequence startup"?
The example demonstrates how to do it dynamically when you execute your sequence file.
jigg
CTA, CLA
testeract.com
(3,515 Views)
Accepted by topic author maxmont
I backsaved to 2014.
jigg
CTA, CLA
testeract.com
(3,514 Views)
I have just my phone.
Teststand doesnt run on Android 😉
I will look at tomorrow.
(3,502 Views)
I tried your example, and it's working like a charm.
Thanks a lot.
(3,469 Views)
