NI TestStand
Disable all the step type at one shot
Requirement 1 - Is there any parameter in Teststand ,where I can disable all the step type not to log the result at one shot .
Requirement 2 - I need to log the result only when the step type fail.
Please let me know for the above 2 how to perform .
Prithviraj
(3,546 Views)
You can perform both with a customized PostResultListEntry callback.
Norbert
Expert: Geometry
(3,541 Views)
Hi Prithviraj,
You could use the Sequence File Callback "SequenceFilePostResultListEntry" and check for the step type you want to exclude, using the following statement:
Parameters.DiscardResult = (Parameters.Step.StepType.Name == "YourStepTypeToExclude")
I hope this helps,
Charlie Rodway | Principal Software Engineer | Certified TestStand Architect (CTA)
Computer Controlled Solutions Ltd | NI Silver Alliance Partner | GDevCon#1 Sponsor
(3,538 Views)
Hi Prithviraj,
You can filter the steps so only fails are logged by using the following expression:
Parameters.DiscardResult = (Parameters.Step.StepType.Name == "YourStepTypeToExclude") || (Parameters.Step.Result.Status != "Failed")
(3,524 Views)
Hi Prithviraj
First Requirement can be implemented by Edit-Sequence Properties-Disable Result Recording for all steps
Palanivel Thiruvenkadam | பழனிவேல் திருவெங்கடம்
LabVIEW™ Champion |Certified LabVIEW™ Architect |Certified TestStand Developer
Kidlin's Law -If you can write the problem down clearly then the matter is half solved.
(3,499 Views)
