NI TestStand
Disable logging to database for a single step
I need to record a step to report but that particular step should not be recorded to database. Any suggestions on how to achieve this?
A part of the database schema I have is:
The schema handles results as follows:
- Logs UUT Results to the UUT_RESULT table.
- Logs Step Results to STEP_RESULT table.
- Logs sequence call step details to STEP_SEQCALL table.
Currently all the steps are getting recorder under STEP_RESULT table.
Also is there a way to make it generic so that when this particular step type is used it never gets logged to database but does show on the report?
Thanks.
CLD
(2,752 Views)
lvrat -
I believe you have two options to ignore a specific step type:
1) You can set the Precondition setting for the STEP_RESULT statement to something like:
    Logging.StepResult.TS.StepType != "MyStepTypeNameToIgnore"
2) You can set the Result Filtering Expression setting for the Database Options tab to
If there was a unique property for these steps, you could use the existence of that property.
- Scott
Scott Richardson
https://testeract.com
(2,744 Views)
