NI TestStand
Disabling Controls in the Full Featured User Interface
Hi Ppl,
I do not want few controls (variables view, stack view) to be displayed in my full featured User Interface. What is the best way to do this. Are there configuration parameters(UserInterface.xml) that could make these controls  in visible. Or Should these controls be make in visible only through the Visible Property.
(3,963 Views)
Why don't you just delete them if you don't want to use them? You would have to modify some of the subVIs such as the Configure ExecutionView Manager. Look at the simple OI example where these controls are not used.
(3,957 Views)
Hi Dennis,
Will Deleting the controls solve the purpose ? I tried moving the controls from the visible part of the front panel. but when the code was run the controls came back to their original position. Then I discovered that the full featured user interface has some code to set the position,size etc of the controls. This part of the code also checks the number of controls present. So I was wondering if just editing the configuration alone could disable the controls.
(3,951 Views)
I don't know what affect the xml file has. If you never want to use the controls, then deleting them will serve the purpose.
(3,943 Views)
Deleting the controls didn't serve the purpose. There are lot of VI's using the deleted control references. So at each node I have to modify the code. Is there a better way to do this ?
(3,924 Views)
Maybe you find this link quite useful...
hope this helps,
Norbert
Norbert
Expert: Geometry
(3,921 Views)
