NI TestStand
Disabling Report Generation on Deployment License
Is it possible to disable the report generation feature on a deployment license?
(2,996 Views)
Howdy Mike -
You can certainly disable the report feature on a deployment machine.  The easiest way would be to first disable the report generation from Configure>>Report Options.  Next, you'll need prohibit other users from having access to this property.  To do this, open up the user manager dialog (CTRL+U) in the sequence editor.  Under your users (or user groups), you can find the property under Privileges.Configure.ConfigReport.  By setting this value to false, the user would not be allowed to reconfigure the report options, and would thus be unable to enable the report generation feature in the future.  Consult chapter 14 of the TestStand reference manual to make sure that the users you create are distributed with your deployment.
Let me know if you have any other questions on the issue.  Have a great day!
Andrew W || Applications Engineer
(2,980 Views)
