NI TestStand
Disabling TestStand ReportView Right Click Menu
Hi All
Is it possible to disable (so it is not displayed at all, or alternatively delete items from, a TestStand ReportView control right click menu?  When I right click on my ReportView control, at run-time, I get this menu.
Things I have tried:
  1. Disabled the shortcut menu of the ReportView control from the Advanced->Run-Time Shortcut Menu option at design time
  2. Attempted to use the Menu palette to delete menu items at run-time.
Nothing appears to have any impact on the menu displayed (shown above) which suggests to me that the menu is embedded inside the control itself.  If that is the case I guess I should be able to access a property of the control that will disable it, but I cannot find any information relating to this.
Any thoughts greatly appreciated.
(4,336 Views)
Hi Steve,
I hope you are well. I understand that you have been speaking with one of my colleagues, James P regarding this issue and has suggested a potential solution for the issue.
Please feel free to post here if the suggestion solution does solve the problem for the benefit of the rest of the community.
Kind Regards,
__________________________
Aidan H
National Instruments UK & Ireland
(4,218 Views)
