NI TestStand
Display TestStand report in modular VI
Hi All,
I'm trying to create a VI (LabVIEW 2011) that is called from TestStand (2010). The purpose of this VI will be to display the test results at the completion of a test sequence. The VI shall contain a button that the user can press to close and continue.
My question is, what is the best method for passing the test results from TestStand to the VI? My best guess is I pass an 'ExecutionView Manager' reference to the VI, then connect the ReportView to this using an IExecutionViewMgr block. However, I could be way off here, as I am not sure how to pass an 'ExecutionView Manager' from TestStand.
I'm guessing the approach will be to create this VI in a sequence that overrides the TestReport callback.
I have attached an image of my initial attempt.
Any suggestions or help would be greatly appreciated!
Cheers,
Cam.
Message 1 of 15
(4,953 Views)
Cam,
why not simply display the report? When configured correctly, the report should look exactly as required and you have the results also available in the future (as file).
just my 2 cents,
Norbert
Norbert
Expert: Geometry
Message 2 of 15
(4,947 Views)
Hi Norbert,
Thanks for your suggestion. This is a valid option, which I will use if I am unable to create a VI that displays the report. The motivation in having the report in a VI is that the sequence can wait while the operator views the report, then continues once they have acknowledged they have viewed the results.
Are you aware of whether what I am trying to do is possible? Can I pass a reference of the 'ExecutionViewMgr' from TestStand into a labview VI?
Many thanks,
Cam.
Message 3 of 15
(4,914 Views)
Hi Cam,
I wrote up a little example which displays the report using a reference to the Execution which is passed into the VI.  Hopefully it should help you out.
Displaying a TestStand Report on the Front Panel of a VI Called With a LabVIEW Step
Justin D
http://www.ni.com/support/
Message 4 of 15
(4,898 Views)
Hi Justin,
I'm sure this is exactly what I am after! When attempting to view the example, the VI file fails to load for me (I have attached an image of the error box). I am using LabVIEW 2011 and have checked the file on two computers. Would you be able to check the file?
Many thanks,
Cam.
Message 5 of 15
(4,890 Views)
Hi Cam,
Here is a version of the VI saved in 2011.  Hopefully you should be able to open this version.  If you are still having issues, you may need to repair your Teststand installation to fix the Labview integration support.
Justin D
Message 6 of 15
(4,855 Views)
Hi Justin,
Thanks again for taking the time to upload the file. Unfortunately I'm experiencing the same problem. Would it be possible to upload an image of the block diagram? That should provide sufficient information for me to understand what is happening.
Many thanks,
Cam.
Message 7 of 15
(4,848 Views)
Hi Cam,
Here you go, hopefully this will help you out:
Justin D
Message 8 of 15
(4,845 Views)
Hi Justin,
Thanks for this. I now have a good understanding of what is happening. When I run the sequence and VI, the report view does not appear to update. Do I need to place the VI in a certain callback for the report to be displayed? Or is there a TestStand configuration I need to make for the report to updated?
Cheers,
Cam.
Message 9 of 15
(4,841 Views)
Hi Cam,
You should only need to pass a reference to the Teststand Execution into the Labview VI from Teststand.  You will need to do this by configuring the Labview module settings to pass the RunState.Execution object from Teststand as shown below.  This reference is what the VI uses to obtain the report for the current execution.
Justin D
Message 10 of 15
(4,826 Views)
