NI TestStand
Displaying Execution time as (N/A) & UUT Result as (Running)Teststand 2010
 I wanted to monitor the duration of the a Sequence Module and Final result PASSED or FAILED at the end of the report.  At the end of the test report gives the following (See Picture) I do not know where I went wrong. Please any help would be greatly appreciated. I am not sure whether it has to do with.ini file may have changed
Execution Time: N/A
UUT Result : Running
Thnaks
(3,597 Views)
Take a look at these for more infromation https://decibel.ni.com/content/docs/DOC-4167
http://forums.ni.com/t5/NI-TestStand/teststand-execution-time-setup/m-p/2354256
http://forums.ni.com/t5/NI-TestStand/Pass-fail-status-UUT-Result-of-my-main-sequence/m-p/2225588
Are you sure the test are completed at the time you get the following? Has this ever worked before? Are you sure you have testStand configured correctly to display these information?
http://www.ni.com/white-paper/8289/en/
(3,575 Views)
