NI TestStand
Distributing LabView Simple operator Interface
I want to make a distribution version with LabView 7.0 and TestStand 3.0.
I made a very small code with only one VI.
If I choose Full-Featured has Operatorinterface, I have no problem of installation on a target PC.
If I choose Simple Operator Interface I have the message " This installer requires Internet 5.0 or later." when I execute setup.exe.
I have Internet 6.0 on my PC.
(3,664 Views)
Hello Lucie,
In order to find out why you are seeing this error message, I would like to take a look at the log file for the installation of your TestStand system when this error message appears. To save the log file of your installation go to Start >> Run on your Windows machine and type in cmd to open the command prompt window. In the command prompt window type “{directory of your TestStand installation files}\setup.exe” /l*v c:\log1.txt. This will launch your TestStand installation and also create a log file in your C: directory. If you could then attach this log1.txt file to this page, I would like to take a look at it to see why you are getting this message.
Kevin Leonard
(3,624 Views)
Keven,
I don't know why but I unable to create the problem again.
Juste in case you could see something, I join you the log file.
Lucie
(3,597 Views)
Hello Lucie,
If you ever experience this problem again, feel free to reply to this thread with the log file of the install that caused the problem, and I would be more than happy to look at it for you.
Kevin Leonard
(3,581 Views)
