NI TestStand
Distribution of TestStand
Hi Simon,
Thanks for the reply and I hope your well today.
Ok, so in TestStand 3+ NI added the TestStand Deployment Utility - this automated alot of steps. However, as this KnowledgeBase explains StationGlobals.ini still have to be added to this utility.
Do My Station Globals Get Included in My Deployment When Using the TestStand Deployment Utility?
However, TestStand 2 doesn't have this utility. However, you may be able to include in the files to include window... Or Im afraid at the very least the file has to be moved manually.
Regarding distributing sequence and code modules in TestStand 2 could use Assemble Test VIs for Run-Time Distribution  function. However, as the document attach explains there is no one set method to distribute sequences. The document also includes information generally relating to distrubting TestStand Applications.
Let me know what you think & thank you for your kind words,
Kind Regards,
Message Edited by Hillman on 10-30-2008 09:30 AM
Kind Regards
James Hillman
Applications Engineer 2008 to 2009 National Instruments UK & Ireland
Loughborough University UK - 2006 to 2011
Remember Kudos those who help! 😉
Message 11 of 11
(808 Views)
